That's what I'm hoping(reply to post at 04:12:35 07/17/23)
(quoted from post at 04:44:40 07/17/23) . I was chewing spruce gum! but the tractor stopped moving forward and began to flex in the middle under my seat. A plastic shroud under my seat that usually is tight to floor mat is now up off mat by inch. Whole tractor is under loadfrom what appears to be something bound up. There were no sounds out of the ordinary like: poping, squealing, or breaking noise the energy just seemed to be absorbed in the tractor instead of rotating the wheels. Shut off immediately by key as soon as I felt the flex. It's been in the flex or stress position ever since. Unfortunately my back went out the next day and is just feeling better today. So haven't looked at it since. My knowledge of hydrostatic tranies is not great but I am a macanical person. I do most of my own work.
The shroud is not holding the tractor up the flex in the rear end is what is holding the plastic shroud up the tractor is under load therfore the middle of tractor, at seat area is the flex point. What I have to do is figure out how to unload the backbend without causing damage or more damage(reply to post at 05:02:24 07/17/23)
(quoted from post at 05:09:12 07/17/23)(reply to post at 05:02:24 07/17/23)
So you have removed the plastic shroud?
(quoted from post at 08:11:45 07/17/23) Tractors, even small ones, should not flex or bend perceptibly under ANY circumstances. Any flex would only be measurable with a dial indicator, in the thousandths, or tens of thousandths, of inches. Any more than that, and the tractor is broken.
As this is a hydro there is no clutch to disconnect the engine from the hydro pump. If the pump is seized or blocked from turning because the tractor is physically broken, the engine won't turn.
From your description this is not a simple "hit it on top with a sledge hammer to straighten the bend out" fix.
I did not bend the tractor I stopped it before anything broke I think. Whit I am referring to as bent is the parts tat ate connected to.the housings, seat ,fenders. When tractor is under stress these can flex. What I have to do is take the load off the rear find out what part in the hydrolics is holding the pressure(quoted from post at 12:05:29 07/17/23) If you did actually bend or distort part of the tractor I
am going to say it is the stamped steel section that
sets between the clutch housing and the transmission
case. I found a parts book but it does not seem to
cover the hydro model. Either way I am sure both
models have a similar assembly. In the attached see
part P21-01 on page 100. It is my opinion that you are
using the tractor for a task that requires a heavier
designed and built machine to complete. I am sure
many on here will agree a machine that is adequate for
a task does not need to ..take a run for it.. to do the
job.
Branson 2800 parts book
(quoted from post at 11:41:42 07/16/23) Hi thanks for alowing me to become a member. I have a Branson 2800 compact tractor and last week I was pulling a log out of the woods, it snaged up I gave it a little running tug and the hole rear of my tractor locked up almost bending the tractor in half shut off right away. It is a hydrostatic transmition. Now it will not start or move.everything is locked up
