Yooper Farmall
Put in new main and rod bearings last night, also put on my freshly painted left rear cast iron center and rim. Wire brushed all the nuts, half nuts and bolts and painted them up.
I'd like to get a new gasket, but I need to know the name of the part it seals up. In the picture, on the left hand side which is the rear of the engine block, there is a cover with 1 oil pan stud that I needed to remove to reach the rear main bearing. There was another cover behind that one. I removed a gasket that I would like to replace but have been searching under "oil pan" and "engine block" on the case-ih parts site and cannot locate the cover.
![a63445.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a63445.jpg)
