I have a Massey 178, 6 speed with Multipower. Sometimes when coming to a stop and trying to change gears it does not want to come out of gear. Then when you do get it to pop out of gear and go through neutral and engage the the next gear it will clash. I find then you have to push the clutch through the secondary stage, put both levers into neutral. Then put it into gear and select Hi or Lo and start again. It does not do it all the time. Sometime it will shift fine for a while then start acting up. I replaced the whole clutch assembly a few years ago thinking that was the problem but apparently not.
