So we have a mf 180 on an international farm that got stuck in low gear. I got it spilt and turns out the shift fork was broken and the rail for the high/low range was bent pretty bad. I'm pretty sure this was caused by a couple of the bolts backing out on the backside of the creeper gear assembly. What is a creeper gear assembly you ask? Well the farm we picked it up from added in a section behind the transmission that gives it an ultra low range. As a result of that the multi-power was tied in the low position and we were advised to NEVER put it in high otherwise it'll destroy the transmission for whatever reason. So my questions are to anyone with experience with these: will using the high range on the multi-power with this creeper gear actually cause damage? If so, I'm wondering if I can just take this whole bit out and go back to factory. The set up of this gear assembly looks like it was made professionally and bought as a bolt on. I just don't see farmer's building something like this. If I can take it out, I have no reference to what factory is so I'm worried. As anyone who has worked on anything before knows it's a lot easier to put something back together that you took apart. I've got the parts in to put it back together, but if we can start using multi-power, that would be the bees knees.
