Diymechanicmike
Hello, I'm in the process of purchasing a mf220 backhoe attachment to use with my tractor. I have a few questions about it. How much does just the backhoe attachment weigh with all the frame mounting brackets and the 2 links? I have a decent drive to go get it and at the moment I only have my single axle trailer I use for firewood and lawn mower hauling and some other odds and ends. My other trailer has freshly milled slabs stacked on it to replace the deck, so its outta commish. Just want to make sure this backhoe attachment doesnt weigh more then 1500-2000 lbs cuz that might be all my trailer can handle. Its homemade so there is no capacity on it. But I did modify it by removing the old rubber torsion axle it had and welded a new axle with leaf springs on it for more weight capacity and ground clearance.
Also had some questions about the unit. At the moment from it sitting it has some surface rust spots on the exposed part of a couple cylinders. Can this be cleaned off with steel wool and hydraulic fluid as the scrubbing agent? Only thing I could think of when looking at it, cuz if that part goes into the housing of cylinder, that dust seal is gonna get scraped up pretty good. I'll probably have more questions in the future but I think that is a good start.
Thanks for any info you can provide.
