Model 40 replacing anti-freeze
Anonymous-0
Drained the fluid out using drain on low point at the lower left
side of the block. Added the new antifreeze a little at a
time...2 total gallons of antifreeze with 1.5 gallons of water.
Ran it a bit to mix it all up and noticed the temp gauge that
has only registered a couple of needle widths from cold in
normal operating to about 2 needle widths from hot. I am
thinking the water has air locked. Anyone have a solution for
this or an idea on how to get it full again? I hate to run it
much more until I get a chance to get the air out as I do not
need another rebuild........
I'm pretty sure the 40 is a thermo-syphon cooling system, that is no water pump. It won't mix the anti-freeze and water very well, if at all. You should have mixed it before putting it in. Were I you, I'd drain it out, catch it, mix it and reinstall it. I suspect it didn't get up to normal operating temperature because you didn't run it long enough. It takes a while and probably even some load to warm it up. I doubt that running non-mixed could have damaged anything, but not really sure about that.
Don't worry about it. It will mix itself. Just warm it up and it will start to circulate on it's own. As long as it doesn't overheat, you're good to go.
If it is a thermosiphon system with no water pump it WILL NOT mix itself, the antifreeze is denser & sinks to the bottom like a slug & blocks the circulation. It WILL overheat & damage the head, head gasket, or worse. You must drain it & mix first.
Thermosiphon systems can't tolerate that. If you don't drain it back out and mix it before putting it back in you won't have to worry about a rebuild. The head or block will be busted. You need another half a gallon of water while you're at it.
I am using extended life Prestone. I added a little water, then some antifreeze, then water, then more antifreeze until it was full, but it is short 1/2 gallon which led me to think air lock. I will drain it and premix as that is what the service manual said, but I thought it would mix OK the way I did it. It is the type lacking the water pump. Thanks for the replies.
Lyle
