jimgoddard
A while back I asked for starter info about notill drills and at least one of the replies mentioned one could be 'made' from a conventional drill and coulter caddy. So, I went off and looked into that but I still have questions. Frankly theres not a bunch of info about this.
First, Id like to understand what makes a notill drill notill. My understanding is its a side by side series of coulters ahead of the openers ahead of seed/fertilizer drops ahead of press wheels. The leading coulters are there to aid the openers which create the 'furrow' at the correct depth for the seeds & fertilzer. The press wheels pack the furrow made by the openers for good seed/soil contact. This differs from a conventional till drill in that the leading coulters are replaced by conventional tillage. From what Ive seen also some conventional drills are missing the press wheels. (Dont understand that though.) Do I understand this correctly??
Back to the 'make' a notill drill business..if I were to go this route Id need a coulter caddy, enough coulters for each seed drop point on a conventional drill and conventional drill w/ press wheels or some other bit to pack the soil. Is that correct? From what little I could find about coulter caddys it looks like they dont come in small sizes (nothing less than 15'). Has anyone made their own caddy? It looks pretty straight forward but you know how that goes. Ideally Id like to use a 10' drill. I think 15' would barely fit thru my gates.
In looking at drills they can be had w/ all sorts of spacing. Is this something that can be adjusted w/ the addition of a new tube from the box along w/ the associated openers etc? The way I see it the bar underneath the box is just a toolbar that can accommodate some fixed number of seed dropping points. Is that correct? Ill be planting grass/legumes and would like a close spacing.
I noticed in notill drills the leading coulters are usually (always?) wavy. Im guessing that this is to aggressively break the soil for the openers. Can other than wavy be used? In other words what determines the type of coulter?
Guess thats it for now. Sorry to be so long winded and ask such simple questions but as I said before I dont know much about drills....but I am trying to learn!!
