Hello,
At beginning of Sep I converted to 12 volt neg ground from 6 vold neg ground. Bought conversion kit from farmtractorrepair.
Made all connections except missed connecting black (ground) wire from key to terminal block. I connected red battery cable to positive battery post. When I touched the negative cable to the negative post there was a big spark. [b:a51e708dd9]Why did that happen?[/b:a51e708dd9]
Tractor would turn over but not start. I took a slower look and discovered the missed connection from the key. Made the connection and the tractor fired and ran great. This was at beginning of Sept.
Now, my son starts the tractor drives it around the farm but then it dies. Full of gas. Must be spark I figure. New alternator with one wire. Ammeter not functioning so I will buy a new one.
Yesterday my son starts the tractor, drives it around the place, but then the tractor stops running and won't start. The tank is full of fresh gas; carb resently rebuilt. I wonder whether the new battery is not being charged by the alternator because the spark at initial connect burnt or destroyed something. [b:a51e708dd9]Any thoughts on what the problem could be?[/b:a51e708dd9]
