ml44special
My son (12) bought a 1969 4020 wide front, syncro, dual hydraulic, no pos traction. He got it at a good price so can do some fixing. We have some questions that we would like to tackle before we tear into it to ensure we do not miss anything.
1. The tractor runs well, but starts hard and smokes blue at the first, I am assuming an overhaul is need, and we would like to put on M&W turbo kit onto it. What overhaul kit should we use and modifications needed to support the extra power.
2. Shifting, going into 5th gear it just grinds, but if we go into reverse and back up it catches 5th gear. Is this an linkage issue or something more in the tranny?
3. When using it the other day, he was riding the clutch and we started getting sparks coming out of the clutch house on the bottom of the tractor. It seems like the throw out bearing is going bad, what else could it be? Should we beef this up too if we add the turbo?
4. 3Pt- This is where we are not JD People so needs some help. The bottom of the tractor where the 3pt hooks up is very loose, has worn pins and very wore. I have different 3pt arms, but what is needed to tighten all that stuff up correctly? Do we need to get inside the tractor to do any of it? IT is ok if we do as we will be cleaning everything. With the 3pt, it also goes up great, but doesn't want to come down until you use other hydraulics. The position lever is in the middle, and we are not sure where that needs to be.
5. PTO, the pto leveler on the right side, grinds a little when pushing it ahead. I have operated other 4020s that never did this, it was always smooth with a snap at when it was engaged. is this linkage or more? If we tear it all apart what should we look at replacing.
6. Steering, when starting steering is slow before it wants to steer, after a couple minutes it steers really tight to the left, but only about 3/4 maybe to the right. I am assuming someone had a narrow front on it, and when the put the wide front on they did not have the steering centered with the front end. Any ideas?
Tires are like new, tins are straight and this is going to be a tractor to be used on the farm cutting hay, baling, hauling manure, but also for play.
ANy help greatly appreciated.
Matt
Matt
