I just did a complete engine rebuild on a T0-20 it has the Z-120 continental Gas engine, however I did replace the oil pump, The engine started right up and ran smooth after complete rebuild, I let it run for about 30 seconds 2 different times and it is showing 0 lbs oil pressure, does anyone know how long the engine should run after start-up before the oil pressure starts? I dont want to hurt the new engine by letting it run too long, i did check the oil pump , I took the plate off the oil pump and looked at the gears all gears looked ok, but there was a little backlash in the to gears inside the oil pump, any Ideas what my cause it not to have no oil pressure? should I just let it run longer? or does the oil pump have to be primed or something? thanks
