oliver hydra electric cylinder rebuild kit
i have an oliver hydra electric hydraulic cylinder. i want to rebuild hydraulic part (packings) not the electric part. casting # is
104 914A . anyone know where i can get overhaul kit and how much $
txs
There never was a "kit" All parts were individual pieces. Also the seal and its part number has been changed several times. I can get you a number and prices if no one else does.
Found this on agcopartsbooks.com
162332AS 1 Package-Piston And Seal (Includes 155784-A O-Ring, 155785-A Sealing Ring, 162030-A Guide Ring And 162031-A Piston)
This was in the parts breakdown where I found the 104914A (barrel)
I don't have a price but you could contact these folks:
John Schmidt & Sons, Inc.
12903 E. Silver Lake Road, Mt Hope KS 67108
800-281-2164
Hope this helps.
Those 104914A castings have used different pistons from the early to the late cylinders. If you are using your old piston that kit may or may not work plus the parts used to seal the end casting have also changed. Parts books are fine but you also need parts bulletins which probably are not on line. That is why I buy local.
