john in la
Came home from work yesterday morning and pickup working fine.
Went to go to work last night and battery seems dead. Check with meter and voltage is very low. I just left it and used wife’s car to go to work.
Since I need a battery for a tractor I stopped on way home and bought a battery.
I get home and check the voltage in truck battery and it is over 12 volts. Now I’m stumped.
I try to start truck and battery goes dead. So I’m thinking starter but lets test some more.
Key off battery shows 12+ volts.
Key in on position battery shows 12+ volts and dash lights on
Key in run position battery goes to 7 volts and then climbs back to 9.5 volts. Dash lights flicker.
Key in start position dash lights go off and battery drops to near 0.
Turn key off and let it sit a minute and battery goes back to 12+ volts.
I still want to think this is a short in the starter but don’t understand why battery voltage drops with key in run position.
Where do I go from here ?????
Forgot to say this is a 2015 Ram 1500 with the V8 hemi.
First problem I have had with this truck.
