Jim.ME
- Location
- Central Maine
That sounds good.thanks for the diagram wired up and it cranked . thank you Lord
Just a bit of common terminology for you. Cranking an engine used to be done by hand with a crank. currently to most mechanics when you say it cranked that means the starter turned the engine over. If the engine starts and continues to run without the starter engaged, the engine is said to be running. I am going with the theory that when you said "it cranked", you meant the engine was running.
No load it on a trailer and get it to the Vocational school for proper wiring and getting the safety switch operating. Get them the manual, if you do not have the correct 555 wiring diagram, so they can do it right for you.
