Brian B Glynn
- Location
- Bemidji, Minnesota
1952 WD45
Issue: Constantly breaking the bolt on the PTO shaft- even Grade 8s. Often after only a few minutes when using a brush hog.
A little history
Oil leak on the PTO gearbox fixed with a new seal last winter is leaking again.
Bolt hole on the PTO shaft is very slightly elongated.
Brush hog spins freely and the gear box holds lube.
Any ideas why I'm going thru PTO drive shaft bolts so quickly?
A little history
