PTO question
The bushing carries the shaft when disengaged and like you said, the coupling keeps shafts aligned when engaged
To answer your question, when PTO is engaged, the shafts and bushing all turn together. But since it keeps everything in alignment, you may have engagement problems or keeping it engaged during operation. Grab the PTO shaft and see how much end play it has before you take it apart. If it is 3/16 or more, the thrust washer may have been lost at previous repair. Excessive end play will give problems of dropping out of gear.
