Mr.Big346
Hey y’all, I have a 1952 Farmall Super A and I just pulled the radiator in order to replace the fan pulley and assembly. After pulling the radiator I noticed a few things: 1) the fan had cut into the fins at one point (not causing leaks but looks bad for a restoration) 2) the overflow tube that runs down the side of the shroud is badly bent. Although unrelated 3) the upper and lower pipes on the engine water jacket show brown rust inside and along the walls of the jacket. Is that normal? It isn’t leaking but can a simple flush of washing soda do the trick to remove surface rust? I have faith y’all know more than me so thanks in advance!
