newgenjdcollector
Bought a decent 8640 with a ring and pinion issue. My original idea instead of tearing into it was to swap out the rear end completely. I acquired a second rear end for the job, but after seeing it upon arrival, I am less optimistic. Both axle seals are leaking and I cannot shift the ABCD range by hand. Seems odd to me. The rear end on the tractor now doesn't have any leaks and I can shift the gears easily. Now I'm wondering if I should just put good parts into it instead of using the donor one. I just don't know what's involved with changing a ring and pinion. Anybody have a general procedure of what's involved?
Right now I have the wheels and fenders off and the fluids are drained. When I pulled the screen it was about 30% covered with shavings. In the bottom of the case I found a small diameter pin, maybe 2 or so inches long. Any idea on what that is?
