I have a TED20, tractor is split, motor sitting in truck rim on blocks, clutch and flywheel removed.
I want to run it to test the rear end seal.
Question is, Is it OK to run engine without the flywheel?
How much movement can i aspect from the engine when running, will it sit happily on some timber blocks or should i chock it to stop it running away?
Cheers: ps. Tony go easy on the shelia's
