sony224422
I have been trying to get my SOS back together correctly. I had to remove/replace my control valve, as the one that was in it had been welded to. The cam Trunnion was welded to, to make the transmission shift with no cable. But was dangerous. With this set up I had 1st, 2nd 3rd 4th and 5th along with r2. I didn t try getting above those gears but I know r1 either didn t work or was weak.
I ended up replacing the valve, and checked all the plungers to make sure they were free. I adjusted the pressures per the manual up to 185 psi, and had it in all 3 test ports. I also adjusted the bands according to the manual.
Now I have 2nd sometimes, 3rd is the only one that will move the machine, and neutral in 5th, 6th and I think 9th. R2 works very slightly, almost like it s slipping. The other gears "hold" the tractor but don t really move it. I took the cover off and noticed the b1 plunger has oil leaking past it. I m assuming from the book this valve is shot too. I also think it might be leaking from between the halves, but I can t tell for sure. I tried tightening the bolts a little but didn t seem to change.
I did also mess with the bands again, I turned the 3 band in while in 5th and it will stop it from spinning. I don t think the bands are bad but I can t seem to get the gears back that I had. And the symptoms don t follow the book- so I am wondering if I m on the right track for the valve leaking is most likely. Hoping to have another to try soon. If that is the case that this one is bad, is there any way to repair them? Or is it not worth it? My original cannot go back in because it is cracked and the shift cam wobbles
