Hello. I have a question about the ignition system on a Tecumseh H60 engine from a JD 624 tiller. The engine ran fine until the connecting rod broke, which was a couple of years ago. I've finally replaced the rod but now the engine won't fire. Crank and cam gears are timed correctly, but I'm getting a weak or no spark even with points and plug gapped correctly. 65-70 psi compression. Would a coil/condenser, etc go bad from sitting for a while? If magneto timing (adjusted by rotating the whole coil unit) was off would that make the engine not fire at all? I've not worked on a Tecumseh before, but the ignition timing looks tricky if I need to pull the head off again. There are a couple of marks on the crankshaft that appear to come before the points would open. Do these relate somehow to the 0.080 before TDC timing setting?
