I teach classes on distributors and magnetos and write articles on electrical topics. To my knowledge the F-4 is the only magneto with a manual spark advance lever. The H-4 and Wico mags don't have one.
As you said, the impulse cuts out at 200-300rpm. What is the timing then, with the manual lever retarded? Then, how much additional timing is there with the manual lever fully advanced?
With an H-4 you get running timing as soon as the impulse goes off. The F-4 is obviously different as there must be some advance when the tractor starts and the impulse goes off. Then, when the lever is advanced, there must be some more advance.
So far, this question for some reason has totally baffled all responders. My motive is simply to understand how the system works! I don't have an F-20 anymore, so I can't experiment.
Again, how much advance is there over crank timing with the impulse on, and running timing with the impulse off and the manual lever retarded? Then, how much additional advance with the manual lever fully advanced? Thanks
