WD 45 flywheel
Anonymous-0
I have ne like I have never seen, It has a blall bearing in the flywheel that acts as the pilot bearing and the pressure plate only has three fingers with mounting bolts on each side of each finger. Can any one tell me what it is I have??
I also would like to know how much pre load the pressure plate should have.
Thanks in advance John
WD45 did not use a pilot bearing. Most WD and earlier tractors did. WD45 had either an Auburn or a Rockford clutch. Some Rockford's had nine springs, instead of six. For details on the clutch setting- you'll find it in the AC-11 I&T manual. Three fingers are normal. Your flywheel and clutch might be from a WD.
