Hi. I repaired a couple broken gates recently by welding on some flat bar to hold the pipe together where they break on the perpendicular joint.
Anyway, where the paint has come off, I have figured out that the gates are made out of 1" (1 5/16" OD) and 1 1/2" (1 13/16" OD) conduit that is electroplated. I have cut and welded hot dipped galvanized angle iron (in the old days) that definitely put off fumes but this conduit doesn't seem to put off any fumes.
I'm just wondering if there is any particular method for welding conduit? It is fairly thin guage and easy to burn through even with my wienie welder. I've got 1/16" and 3/32" rod in 6011, 7014, and 7018AC. If worse comes to worse, I could get out the 110v mig with .035" flux core wire which I can't get to work on mild steel although I may try some smaller wire like .030" flux core (no gas available). I haven't compared the price of conduit to the same size in mild steel but conduit may be the route to go for outdoor stuff till it gets all bent up. Thanks.
