Sometimes simple fixes avoid spending moneyOccasionally simple fixes will correct what may seem to be complex or expensive problems. Always check the simple things first and possibly avoid expending time and money. Obviously selling carburetors, generators, starters and rebuild kits is good for our business, but not if it does not fix your problem!
Simple Fix #1 - Runs poorly when warmed upBefore replacing the carburetor, check the fuel line, sediment bowl and tank outlet. With old tractors these often become clogged with rust sediment and cause the engine to run as if the float and float valve are damaged. The symptoms are usually, the tractor will run fine when started but begin to starve out and miss after awhile. It is also easy to associate this condition with warming up ("it runs fine till it warms up").
Simple Fix #2 - Dies when warmed upWhen the tractor warms up it unceremoniously dies with no spark. The spark does not come back till the tractor cools down. This is commonly a bad condenser. Since testing condensers appears to be a lost art, it is simplest to replace them.
Simple Fix #3 - Good battery won't actuate starterThe starter just won't crank over your 6-volt tractor. Before replacing the starter, check for warmth at the connections of your battery cables. Your cables may be too high of gage (the wire is too small) and your connections may be less than perfect. Remember that 6-volt systems draw more amperage and the connections and wiring and connections should be near perfect for the starter to function as it was intended.
Simple Fix #4 - Won't start, getting gas & sparkYou have spark at the right time and gas is getting on the plugs, but the tractor won't start. If the tractor has been sitting for some time, it is likely that your gas has gone bad. Drain and replace the gas with new.
Simple Fix #5 - Won't start, water in distributor capIf you have trouble with your tractor during high-moisture times, such as during a thaw, check under the distributor cap for moisture. Dry it all out inside and you will be on your way again.
Simple Fix #6 - Overheating or not chargingYour tractor is overheating. Before you replace your water pump, thermostat, and radiator cap, be sure that you have the correct width and profile v-belt for your cooling fan and be certain it is tensioned properly. This can also cause the charging system to appear to be bad.
Simple Fix #7 - Boiling out radiator fluidYour tractor boils out your radiator fluid whenever it warms up. Before replacing the thermostat, be sure your radiator cap is rated correctly for your system and that its spring and seal are still in good shape. The cap may be "letting off steam" under what was supposed to be normal pressure.
Simple Fix #8 - Burning Oil?You have good compression on all cylinders indicating that your valves, pistons, and rings are in good shape but you have traces of oil smoke coming out the exhaust. This can be caused by your oil-bath air filter. Be sure that you are running the correct weight of oil. If the oil is too light, it will be drawn into the engine. Don't go overboard the other way, if the oil is too heavy, it won't clean the air.
We sell tractor parts! We have the parts you need to repair your tractor - the right parts. Our low prices and years of research make us your best choice when you need parts. Shop Online Today. Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V.
Yesterday's Tractors - Antique Tractor Headquarters |
