KentuckyHick
Greetings, new to the forum, Ive read through a bunch of old post but cant find anything like what Im dealing with. I recently started working on a 58 130, it would start and run fine but wasnt charging. It is a positive ground system. I replaced the regulator and the wiring from generator A terminal to GEN terminal on regulator, & F terminal on generator to F terminal on regulator. I also changed wire from BAT terminal back to the positive post on the charging gauge. And the wire from the L terminal back to ignition switch. I also changed the wiring on the distributor to the positive post on coil and negative post on coil back to ignition switch. Also changed the wire from starter switch back to charging gauge. I replaced the wires one at a time and looked at a service manual and I believe I have it wired correctly. Now it wont start at all. Like I mentioned I believe I have it wired correctly but now no start. I can use a jumper wire from negative terminal on coil to the negative battery post and it will start right up. I was thinking maybe the switch, I have removed it and cleaned where the switch mounts to the control panel but it didnt help. Just wondering if anyone has any suggestions. Im stumped.
