FORD 640 WON'T START.
WHATS BEEN DONE SO FAR:
Rebuilt engine; new sleeves, pistons, rings, crank bearings and seals. Also new valves, springs and guides. New spark plugs and distributor dust cover.
Starter wouldn't handle torque of "new" engine, had it rebuilt.
CURRENT CONDITIONS AND SETTINGS:
Good spark at all plugs.
Points clean and set to spec.
Firing order 1243, C/W.
Initial timing set with 4 deg mark at timing window mark.
Distributor housing set so that points are just about to open for #1 @ 4 degs BTDC.
#1 dist cap terminal is at 1:00 position
Battery fully charged
Power jet needle 1-1/8 turns out, idle needle 1 turn out.
Won't fire but will pop and backfire when distr. rotated CCW.
Even tried a shot of starter fluid.
It has run since rebuild, had to pull it off due to sick starter. Would only run when distributor was rotated 90 degs. counter clockwise from "correct" setting of 4 degs. BTDC and points just opening on cyl 1. It ran well though.
I suspect timing issue, but I feel sure that I did it right, of course that's one man's opinion!
Hope you can help, I've come too far to get stumped at this point.
