Bought my 850 a year ago and have been restoring it. Got it running great but noticed it wasn't charging the battery. After a little diagnosis I found that someone had wired it for 6v negative ground system. Wiring was old with cracked insulation so I bought a restoration quality wiring harness and wired it according to factory diagram in the maintenance manual bringing back to a positive ground system. I also bought a new Voltage regulator and generator that was a replacement for the original part number to insure I had the right regulator for it. The new generator is an OHA-10125-A and is suppose to be a replacement for the original part number. I verified all wiring was correct according to the diagram and that I had a good ground at the VR. Polarized the generator before I started it. It started right up, but I noticed the ammeter was pegged at 30 amps. Turned the lights on and it went to 20 amps and stayed there for a while and then went to zero. I assumed the regulator had stopped the charging because the battery was fully charged when I started. Occasionally it would show it charging at 30 amps and then go to around zero. Turned the tractor off after about an hour of operation and noticed that the system was discharging at about 20 amps and lights were off. Checked the VR and it was fried. Replaced the VR with another new one, this time the one that the place I bought the generator from recommended. Stamped on it is "6 Volts Positive Ground B-Circuit" so I assumed I was ok there. Repolarized the generator and started the tractor. Same thing happened and the VR smoked. I have rechecked the wiring and grounds and everything still checks out. Could not find the specs on the generator I bought but it is a 6 volt generator. I suspect it is the generator but want to know for sure before I send it back. Any thoughts on how to diagnose the problem would be greatly appreciated.
