The main output fitting is controlled by the quadrant control when the valve is engaged. The pressure tops out at 2000psi and is variable. The engine lugs down under load when I do this check so I assume this is bad for the pump?
The question I have is I think I need a 3 way valve to run a snowplow lift cylinder and a 4way valve to run the turn cylinders. I would like to do this with a 2 spool valve but haven't been able to find one. So I guess I need one with power beyond and one with open center, does this sound right?
