(quoted from post at 13:57:47 10/06/23) Used to be more common, one-time dad unhooked the jumper cables from the JD R, and the battery blew up in his face. He was lucky, it didn't seem to hurt him.
That's why when using jumper cables you should hook one cable away from the battery, connect it last, unhook it first. Yours wasn't caused by using jumper
cables, must have been an internal spark.
away" is key word, not "pos/neg"(quoted from post at 12:26:11 10/07/23)(quoted from post at 13:57:47 10/06/23) Used to be more common, one-time dad unhooked the jumper cables from the JD R, and the battery blew up in his face. He was lucky, it didn't seem to hurt him.
I read the complete post before posting this. The above is correct but no one mentioned one important thing. When using jumper cables, always hook up the negative cable last and someplace away from the battery.
When unhooking jumper cables, always unhook the negative cable first.
(quoted from post at 10:19:31 10/07/23)away" is key word, not "pos/neg"(quoted from post at 12:26:11 10/07/23)(quoted from post at 13:57:47 10/06/23) Used to be more common, one-time dad unhooked the jumper cables from the JD R, and the battery blew up in his face. He was lucky, it didn't seem to hurt him.
ame with pos not hooked up, no spark.(quoted from post at 13:26:38 10/07/23)(quoted from post at 10:19:31 10/07/23)away" is key word, not "pos/neg"(quoted from post at 12:26:11 10/07/23)(quoted from post at 13:57:47 10/06/23) Used to be more common, one-time dad unhooked the jumper cables from the JD R, and the battery blew up in his face. He was lucky, it didn't seem to hurt him.
pos/neg are key words here. Without that neg cable hooked up, there is no way you are going to cause a spark at the battery by hooking or unhooking the cables.
(quoted from post at 12:34:21 10/07/23)ame with pos not hooked up, no spark.(quoted from post at 13:26:38 10/07/23)(quoted from post at 10:19:31 10/07/23)away" is key word, not "pos/neg"(quoted from post at 12:26:11 10/07/23)(quoted from post at 13:57:47 10/06/23) Used to be more common, one-time dad unhooked the jumper cables from the JD R, and the battery blew up in his face. He was lucky, it didn't seem to hurt him.
am certainly not arguing.....just stating fact. All that is necessary is that the last of the 4 connections made needs to be [u:261ce205ff]away[/u:261ce205ff] from the battery! POs/neg, don't care, last connection can perfectly well be at the starter switch or solenoid. That is away from battery by the cable length, whether it be pos or neg. and it is not ground!(quoted from post at 15:40:38 10/07/23)(quoted from post at 12:34:21 10/07/23)ame with pos not hooked up, no spark.(quoted from post at 13:26:38 10/07/23)(quoted from post at 10:19:31 10/07/23)away" is key word, not "pos/neg"(quoted from post at 12:26:11 10/07/23)(quoted from post at 13:57:47 10/06/23) Used to be more common, one-time dad unhooked the jumper cables from the JD R, and the battery blew up in his face. He was lucky, it didn't seem to hurt him.
The trouble is that one has to hook up both of them when jumping a battery. As I said always hook up the ground last and away from the battery and unhook it first.
You can argue with that till the cows come home, it still remains true.
(quoted from post at 13:06:40 10/07/23)am certainly not arguing.....just stating fact. All that is necessary is that the last of the 4 connections made needs to be [u:b1bc1cbef8]away[/u:b1bc1cbef8] from the battery! POs/neg, don't care, last connection can perfectly well be at the starter switch or solenoid. That is away from battery by the cable length, whether it be pos or neg. and it is not ground!(quoted from post at 15:40:38 10/07/23)(quoted from post at 12:34:21 10/07/23)ame with pos not hooked up, no spark.(quoted from post at 13:26:38 10/07/23)(quoted from post at 10:19:31 10/07/23)away" is key word, not "pos/neg"(quoted from post at 12:26:11 10/07/23)(quoted from post at 13:57:47 10/06/23) Used to be more common, one-time dad unhooked the jumper cables from the JD R, and the battery blew up in his face. He was lucky, it didn't seem to hurt him.
(quoted from post at 13:06:40 10/07/23)I am certainly not arguing.....just stating fact. All that is necessary is that the last of the 4 connections made needs to be [u:d8a9c468d7]away[/u:d8a9c468d7] from the battery! POs/neg, don't care, last connection can perfectly well be at the starter switch or solenoid. That is away from battery by the cable length, whether it be pos or neg. and it is not ground!
here are two examples.(quoted from post at 12:58:19 10/09/23)(quoted from post at 13:06:40 10/07/23)I am certainly not arguing.....just stating fact. All that is necessary is that the last of the 4 connections made needs to be [u:75cb177a4e]away[/u:75cb177a4e] from the battery! POs/neg, don't care, last connection can perfectly well be at the starter switch or solenoid. That is away from battery by the cable length, whether it be pos or neg. and it is not ground!
The point was to make the connection "away" from the battery. How do you make a POSITIVE connection away from the battery?
Literally any metal spot on the donor vehicle is a NEGATIVE connection, and there are plenty of spots to clamp on which can handle the amps, but the only place to make a POSITIVE connection on 99.99999% of vehicles out there is AT THE BATTERY. No other positive connection is heavy enough to handle the amps.
My early 2000's Chevy trucks had a positive lug for jumping, but it was near the battery.
(quoted from post at 12:17:48 10/09/23)here are two examples.(quoted from post at 12:58:19 10/09/23)(quoted from post at 13:06:40 10/07/23)I am certainly not arguing.....just stating fact. All that is necessary is that the last of the 4 connections made needs to be [u:7a767c8846]away[/u:7a767c8846] from the battery! POs/neg, don't care, last connection can perfectly well be at the starter switch or solenoid. That is away from battery by the cable length, whether it be pos or neg. and it is not ground!
