TapRackFire
Looking for some advice on my 530 CK that I picked up the other day. This beast has not run in about 10 years, but I was assured it ran when the PO parked it. The PO let me drag it off for free. Said he only stopped using it b/c it leaked hydraulic fluid everywhere and that is pretty evident by the looks of the back cylinders by the hoe.
I pulled the injectors and flooded the cylinders with Marvel Mystery oil. I waited a few days and rolled the fan blade by hand and the motor turned a little. When I stuck a battery in it and bumped the starter the engine turned without hesitation about 1/4 turn and then STOPPED. I can't get it turn anymore with the starter or the fan blade. I pulled the starter out and tried to roll the flywheel with a bar but I could not get it to turn and it was really hard to get good spot to pry with the loader arms in the way so I put the starter back on and all it does is "click" like it is engaging the flywheel, but it can't overcome whatever is holding the engine.
The motor had the air cleaner and exhaust stack tightly attached so the motor was no open for water to flood in through those two places.
I jacked one of the rear tires off the ground and put the tractor in 4th and rocked that tire till I was sick of it. All I heard was a clicking sound in the axle. I never could get any results with the rear wheel regardless of the gear I chose, to include neutral. I thought I had a good chance of using the rear wheel as leverage to turn the engine, but I was wrong.
This unit does have a torque converter and a directive drive selector on the steering wheel. Does this require me to do something special to get this motor to rotate by hand?
I was thinking about removing the hydraulic pump from the front of the engine so I could have access to the front of the engine to install something to the crankshaft that would allow me to rotate the motor at least backward 1/4 of a turn and try working the engine back and forth.
Any suggestion?
Tap
Any suggestion?
Tap
