onetotaltoolman
Hi Guys - just started a total rebuild of a 1959 D-14. I look at this in my outbuilding and think,,,,there is hope. Taken everything off the front end to start
replacing leaking seals. First up is a decision or two to make on the power steering unit. I have it out on the bench, and have reviewed the service manual a
little on it's internals. Main question for those that have been down this path - seals and leaks. Two seals for sure that have to be replaced - one around the
bottom steering shaft, and another in the steering control valve where the steering shaft exits the control valve. I have those on order. With that, can anyone
chime in on common problems i should try to solve while this thing is out of the tractor. I see paper gaskets between steel shims on the bottom of the steering
shaft retainer, and o rings in the steering control valve and steering ram. If i could order those, hey great, but my internet searches don't make this an easy to
find gasket rebuild kit. So, any info from the experienced would be greatly appreciated. Thanks - Toolman.
