toolgarage
All,
I have two Ford tractors - 2810 and 5600 that both have 2-port hydraulics out the rear by the 3 point. I just purchase a forest mulcher that has a hydraulic motor with 3 hoses off of it. I understand the 3rd hose is a motor pressure relief that is supposed to run back to the sump or
hydraulic tank.
Couple questions
1. Can I run this mulcher off of the standard hydro block if I hold the lever? if not do they make a different hydro block that can be turned on/off?
2. Any ideas on how to connect this 3rd hose back to the rear end sump? Are there any additional ports on either of those rear ends that could be used? Open to suggestions.
BTW - the mulcher takes 10GPM and the 5600 is rated at 9.6GPM and the 2810 is 7.7GPM. I know both are under but I'm good with it running a little slower.
Another option it to pick up a PTO hydraulic pump and tank, but trying to see if I can get it working with what I've got first.
Thanks!
Tim
hydraulic tank.
Couple questions
Thanks!
Tim
