(quoted from post at 06:13:35 04/01/13) what size gravel would you use to clean a tank? I am planning to fasten it to tractor wheel.
(quoted from post at 06:44:23 04/01/13) Just this last month I was working on some carburetors that had sat in unused tractors for about ten years. The gas had Sta-Bil in it and had turned to asphalt. I got some MEK and thought it would cut it if anything would. It never even got dark. I ended up using toluene and it worked ok. Not fast, but ok. We ended up putting some E-85 in the tank of one tractor that was particularly bad. It actually cut the crud about as good as anything we tried. Mike
(quoted from post at 18:21:45 04/01/13)
I find it to be totally amazing that there are still folks out there who actually believe that old myth of putting rocks or chains in a gas tank to clean it out. And even worse, now you're going to hang it on a wheel and drive around that way? What happens if the tank slips a little and makes contact with the ground? Are you prepared to go shopping for another tank?
Come on guys. There are many, many chemicals available that do an excellent job with no risk of ruining an otherwise good fuel tank. 9 times out of 10 all you need is fresh fuel, and if you want to go one step further, use E85.
The little bit of rust left in the tank will be easily caught in the sediment bowl. Just clean the sediment bowl a few times and you're done.
(quoted from post at 11:03:22 04/01/13)(quoted from post at 18:21:45 04/01/13)
"The little bit of rust left in the tank will be easily caught in the sediment bowl"
If you are not going to do it right then yes you will still have a contaminated tank... The ones I have done were in bad condition no chemical I know of that would eliminate the rust... I put enuff gas in my tractors to do what I plan to do one time,,, add as needed all the tanks I have lined in the past 10 years look like I just lined them and never had to clean the fuel filters...
If you are going to prep the surface for a liner it needs to be prepped just like you were going to paint the outside only you can not get to the inside,,, rocks, nuts, nails, chains what ever it takes prep it and you will be a happy camper,,, are haftarse it and join the group that were to lazy to go the extra mile... Prepped and lined correct and you are done with it forever...
I find it to be totally amazing anyone would question the efford unless they could buy a good tank reasonable... Me, if I am going to this much trouble I line the tank I am done with it forever (I hope)![]()
