JD 70 power steering
mdross
Finished restoring my JD 70 played with the power steering today it being the later version. Checked the bypass pressure near 1200lbs. Set the normal flow by the book up to the spring then 2 full turns. Finally ever so slightly tapped the valve back and forth till the wheels stayed centered. Hoping that using the tractor will loosen things up so the steering will work the way it should.
Anyone have anything to add?
Mike
