Glen D Anderson
Good morning,
Our '72 4020 leaks significantly from the steering motor pinion seal during cold weather operation. The colder the weather, the worse the leak. For reference, last week when operating at - 20 F, the leak was a steady stream. Once the tractor and/or ambient temp. warms up the leak stops or slows to an imperceptible amount. This is spite of the motor being completely resealed several years ago.
To test: I removed the motor case drain line and operated the steering and found no discernible flow coming from the motor.
I installed a pressure guage on the hydraulic cooler where the steering motor case drain line connects to check for back pressure. At med. idle the back pressure was 10 PSI and rose to 16 PSI at high idle.
This testing was done at + 32F so one might assume that back pressure readings would be significantly higher at - 20F???
I'm planning on checking the cooler return plumbing for restrictions but was curious if anyone has run into this before & if there is any valving or components in the cooler return circuit that could cause the back pressure?
Thanks in advance!
Glen
Thanks in advance!
Glen
