I've got a Massey Ferguson MF31 sickle mower that I bought at auction for a couple hundred bucks. My plan was to use it to cut along pond/creek banks and in the vertical position as a "hedge trimmer" to keep paths clear of overgrowth. So far, I 've just used it in the vertical position and it works great. I haven't changed any knives or anything on it....yet.
Last week I was trimming some paths and the tip got caught on a branch it couldn't cut. I always trim at lowest gear/speed just so I can catch that kind of stuff. It stalled the mower ??? and I shut down as quick as I could. Turns out that the bar pulled backward far enough to pull the drive pulley out of alignment and the belt caught on the frame. Looking at the frame structure (and the parts breakdown) the only way I can see that happening is to twist the main tube that the drive pulley, idler pulleys and the head are all mounted on. There is no obvious distortion or cracking on the tube at all. The idlers are still in line with the head so it's the drive pulley end that got twisted. It appears that all I've got to do is cut the mounting bracket for the pulley trunnion, rotate it back in line and reweld. Anyone experienced anything like this before? Is my thinking correct on the solution (cut/rotate/reweld)?
Also, as you can see the drive pulley has seen better days. (This was the condition when I bought it).
I'm amazed it's held up this long and as long as it was working, I didn't want to mess with it. Well, now that I'm going to disassemble the drive, I figured I'd address the pulley as well. I could only find one in a Google search, several years old on ebay and it's long gone. I've found some pulleys, close in size, C belt that you specify a bolt-on hub for. However, when I removed the pulley, I found that the shaft is tapered with a keyway (1.05" down to .810). This is over a 1.5" length, so about 1.5"/ft. if my math is right. There are tapered hubs out there but before I go crazy trying to see if one will fit, I thought I'd pick the brains of guys on here. Anyone run into this before trying to replace that pulley and come up with a workaround using available parts?
Thanks for any help you can give.
