Tom Schaech
Hi everyone...
I"d like some input from folks who have more experience working on these than I do--my business is air-cooled small engines.
I recently bought a JD60 NFE. PO told me they were sure the head gasket was blown--found coolant behind one spark plug. Got it into the shop, tore it down. Found neoprene part of gasket badly shriveled. Little water and surface rust in left cylinder. Cleaned all up, installed new gasket and reassembled. Fired up easily enough, but spit coolant out of the exhaust for a few minutes. Thinking it had to warm up and seal well, let it run for a while. Shut it down and started next day; same thing.
Pulled back into shop and tore down again. Found small amount of coolant on top of left piston. No external leaks of any kind, no oil in coolant when drained both after getting it and before this recent teardown.Changed oil during initial rebuild; no water in oil.
I"m thinking either I didn"t properly torque gasket or crack in cylinder head. Inspected block for cracks in cylinder sleeves--none. No crack between cylinders. Took the head to a machine shop and am awaiting report.
I read somewhere that 60s were "famous" for cracks in block. Any thoughts or experience here? There are no welds or anything that I can find to indicate a freeze crack.
Would appreciate any feedback!
Thanks!
Tom
Thanks!
Tom
