Mad Farmer
- Location
- Northeast
How close is the nearest big tree?
Hey All-
So We have had a very wet spring/early summer, and I was trying to get something done a little too fast after the rain and have sunk my tractor pretty good.
I buried it more trying to get unstuck. This is a 2 wheel drive Ford 4500, and i have a hay spear on the loader right now.
I have tried the trick attaching logs to the wheels like a paddle and all I have managed to do is dig out a deeper hole with those.
Im feeling like I am at the point where I don't have any other ideas and am going to need to call someone for help.
What kind of person do I call to pull my tractor out of the pasture?
So what is your way ?
Never seen anyone hurt doing that, but know 2 that came so close neither them or I will ever use a strap. YouTube has many videos that show why straps are very dangerous.Sounds like u have no experience getting a tractor unstuck. When it’s stuck it’s stuck do not dig it down to make things harder. Can’t see how bad your stuck either. Now u need a tractor at least 2 times bigger or a 4 wheel drive or even a crawler. Plus is there hard ground close cause if it’s all swamp then it’s a waiting game. Also use good high rated nylon straps. Or a 2 inch tow rope. A chain is useless when pulling something stuck out. U need a couple ft of slack then pour the coal to her. And also pull it out from the back the same way it went in. And be on your tractor and have it in reverse to help out. The longer the cable or strap the bigger the tractor u need. So check your neighbours to see if they have a 4x4 tractor.
Check with a local contractor with a crawler or fair-sized excavator, if you don't have a neighbor nearby with a large tractor as has been suggested. You have tried the logs to the wheels trick and went deeper you say. You can keep trying other ideas and mess with it for a long time or bite the bullet now and get the right help to get it out. JMHOHey All-
You never EVER see professional recovery crews yanking on stuff.Snug up the chain/strap then apply the power. None of that ripping and tearing rough stuff.
Check out Yankum Tow ropes they are made to be yanked on as they stretchYou never EVER see professional recovery crews yanking on stuff.
If you have to yank on something you probably don’t have enough weight or proper rigging in the first place.
that is true! but people are not reading what i am posting. i said "rated slings." and did not say to take a run at it. it was tighten up slowly till you have a slight bit of slack meaning so the sling is barely touching the ground which is about 2 feet of slack, then giver. its the sling shot effect u want . and no chains are allowed on any drilling rig location for hoisting or pulling stuck stuff. its all rated cables or slings for the job. you guys make it appear like i know nothing, and pretty much have to draw a picture with the proof. and also recovery units dont have to yank as they have all necessary proper rated equipment, and their in that business. i am always preaching safety . this is just a little stuck farm tractor. use some sense. and if we saw this stuck tractor would make things easier. like is it up to the seat or just the drawbar and how much of a mud hole ?You never EVER see professional recovery crews yanking on stuff.
Clearly you need another tractor. One to use, and one to pull it out when you get stuck.Hey All-
