I've been lurking on the site for a couple months so I figured I ought to register and say hi.
I have an early '50 8N (front mount distributor).
I use it to bush hog my 9 hilly acres and have an old 5 ft King Kutter bush hog.
I bought the tractor in March, and it's the first tractor I've owned. I'm not super mechanical, and I'm really not good with electrical stuff, but I'm not new to old Fords though....I own a 63 Galaxie that I've had since 1987.
I changed out the oil, filter, and changed trans/diff/hyd fluid right after I got the tractor. I also recently did plugs, points, rotor, cap, and condenser. The old fluids were predictably nasty. I added an ORC and replaced the PTO shaft after a forward gear to reverse gear newbie error with the PTO engaged. It has a new 12v coil as of this week too.
The tractor was converted to 12v sometime in the past, but runs a generator instead of an alternator.
The hydraulics work good and I get over engine 20 lbs oil pressure after working it hard in hot weather.
The tractor smokes a little, and worked great for a couple of months. I'm currently chasing a weak spark issue. I can use it for like 30-45 minutes, then it starts running like crap (missing, sputtering), gets weak, and dies. I checked fuel flow at the bottom of the carb (seemed good), and checked spark with the tester Bruce listed in a previous article. The spark was really weak and non-existant on one plug wire. If the tractor has a ballast resistor, I certainly can't seem to find it. It also has an exhaust leak at #4 cylinder at the head and also at the hook up joint for the muffler pipe. I've got a new manifold and muffler coming from YT--they should arrive later this week.
Brent
Brent
