Fuddy Duddy
Got the engine in the machine shop. They said it has a cracked cylinder and bent rod. Just one of those things. No indication why it happened. It has a cast iron head. They said they can fix it for a $1000. That's a new Sleeve in that cylinder, Bored, new pistons & pins, rings, Rod & main bearings, thrust washers, timing components, New oil pump, cam bearings, lifters, freeze plugs, oil galley plugs, cam shaft, Rebuilding the head connecting rods (replace the bent one), push rods rocker arms and o'cousre gasket set.
They seem to know what they are doing. Got to talking about Ford "N"s the old guy said he cut his teeth on them.
I know I couldn't turn around and get haft of what I'm putting in to it. I just want it dependable for my Daughter as she will be going off the college this next Fall. I think this is the best way to go about it. You can't go out a buy a car for three grand and not expect problems. Now this car will be basically new. I had just bought new tires, alignment and starter and Brakes three weeks before. That was a grand itself. Only real thing left is the transmission (Knock on wood)
I'll left her worry about the real sell value in five years when she has a job and wants to trade it in for a car that she will be paying for.
