I got a 98 dodge ram that has sat unused for a couple months now, and previous to that only started a couple times to move it out of the way of something. I have it setting for sale beside the road..e tc. as luck would have it, and my fault.. battery flattened out.. It wanted to start, but not enough juice.. so i jumpe dit with my tractor.. it started, stalled, then I restarted it and it set a code I guess.. check engine lamp came on. otherwise ran good like it did before.. idled ok, little hesitant at first.. but then it hasn't run in a while.. revved ok.. oil pressure ok.. volt meter said ok.. etc.
anyway.. about the check engine code. I'd like to fix that before selling it, if it is either just a code that set somehow due to the hard start attempts, or if some easy bolt on thing like an 02 sensor.. I'll change it out before selling it. truck is cosmetically rough, but engine has been ok.. i'm selling cheap, so don't want to put a ton of money in it.. but if a 25$ sensor or something.. sure..
I have a cen-tech HF obdII meter I got off a buddy earlier this year for in exchange for some work on his property... still new.. he hadn't even put a battery in it.. he bought it to use, and never ended up using it.. etc. so I got the scanner and it's manual and case etc. anyone know wher ehte port on a dodge ram is.. should be unde rthe dash within a foot of the cluster or so.. right?
otherwise.. any tips or ideas on the code? could the hard start have caused it?
I have the battery out now on a fast charge and will go out and check it in a bit.
tips appreciated... especially from any of you guys that also fix cars for a living..
soundguy
soundguy
