onetotaltoolman
About 1/2 done with a pretty much complete overhaul on the "field find" D14. Done with the front half, now headed south. First repair - PTO engagement lever is leaking. Parts book shows an O-ring on the shaft. Have not looked thru repair manual yet, but i'm hoping i can remove the traction booster spring, drop the pan, and get to the seal from the bottom. Anyone done this repair yet?
Lighter side- did a ton of work on the front half of this tractor- engine, power steering , etc,etc. Finally got to a point where i could drape the new wiring harness across the frame, put the battery in, hold my breath and hit the start button (has not been run in many years). Much to my surprise, the engine fired up instantly . Couldn't believe it, and my awe quickly turned to the 1/8" steel line that i had forgotten to attach to the rear of the traction booster gauge. Icarumba - a jet stream of oil sailed across the shop nailing the window some 20' away. Could not believe the little tiny oil line could shoot out enough oil to cause a valdez slick in my garage.
