OregonAaron
Hey there, I was seeking opinions on repairing a radiator. Yes, I know the correct way to do it would be to take it to a shop and have them solder it. So, I did something dumb and wacked the radiator with a wrench when replacing the fuel pump and it now has a slow leak in one of the vertical tubes. The leak is in the middle and no where near the tanks. The hole is very small and I cant even see the hole, just a area of a few smashed fins and a weeping leak. I was planning on taking the radiator out a assessing the damage. So, if I cleaned the area very well could I JB weld a small leak? Also, are these radiators brass? I could try to solder it if so, but I have not done any real low heat soldering in quite some time... I don't want to make a bigger problem!
