Gents,
Last night I fired up a recently acquired Super C. This tractor has been sitting at least through last winter, beyond that I don't know. Prior to starting I changed the oil (30W non-detergent) and Napa filter (Wix). The oil pressure gauge pegged. I let it run for about a minute and then shut it down. The bottom end sounded fine, ran smooth on all 4, and the top end sounded good as well. A couple hours later I fired it up again for about 30 seconds. This time I paid a little closer attention to the oil pressure gauge. When it first started the needle rose to about halfway and then paused there for a second or two. Then it started rising again until pegged. I also had the valve cover off the second time. There is a fair amount of oil sitting on top the head but I saw very little oil, if any, coming through the rockers. Maybe you don't get much in 30 seconds?
I have checked the rocker arm center support stud. It is the correct stud and installed correctly. It's got the coarse-fine thread stud, so you can't easily make the mistake of installing it upside down. I also pulled the filter off just to check and it was full of oil (it was). The filter housing passages appear clean (no blockage).
How likely are the pressure relief valves to stick on these engines? My biggest fears would be spun bearing or oil galley blockage.
I have another pressure gauge that I am going to put on next and verify that it indeed has high pressure. Assuming the second gauge confirms the next step would be to pull the pan and the oil pump to check the pressure relief.
I appreciate any thoughts you guys have.
Thanks,
Aaron
Thanks,
Aaron
