Took my 961 out for a ride tonight and noticed what I think is a definite miss in 5th. gear at about 1700 rpm. Pulled it back in and started pulling the plug wires one at a time off the distributor cap. Cylinders 2,4 and 3 a big difference when removed. #1 no difference at all. OK, I figure bad wire or plug. I swapped the # 1 wire with # 2 and still no difference at idle when #1 removed. OK, bad plug. I put in a new plug and same deal. So I remove the plug and ground it. Firing fine. Also might mention, I have strong blue spark on all 4 from cap. Only thing I noticed is it seems like the # 1 plug is dry as a bone and still sandblaster clean like it's not even firing. Almost like there's no fuel getting to that cylinder. Is that even possible? Like I mentioned, the plug is firing when removed and grounded. Just no difference in running at idle when I isolate that #1 cylinder. Timing is set at 5 degrees. Any ideas?
Thanks!
Thanks!
