Since I rebuilt the engine (ad3.152) this summer, I've experienced this issue when the tractor inclines probably at 30 degrees or more it will die. I've then become a master at fixing it where I'll raise the front of the fuel tank, loosen the two front injector lines, crank over a few times where fuel will start to shoot out (after 2 cranks roughly), then tighten, and the tractor will run again...until I incline it again.
This problem did not exist before I rebuilt the engine.
If I run the tractor on level ground, it will run for hours with no problem and does not stall.
I have about 80 hours so far on the new rebuild and this has been going on from the start, but I thought is was related to a faulty fuel pump. I've replaced the fuel pump with the bowl type and the problem still progresses...the problem existed with my old fuel pump (bowless) and with an additional new fuel pump (bowless) which I thought was causing the problem.
I also checked and replaced the tap and screen and it has not been clogged at all. I replaced the fuel line from the tap to the pump, as well as the line from the tap to the first primary glass bowl type filter. The bowl in the fuel pump shows no air bubbles. And there are no leaks in the entire system.
I've also tried bleeding the system periodically at the secondary bleed banjo fitting for air, but no air exists...just pure fuel. Then again at the lower bleed 5/16 wrench size screw on the CAV injector pump, as well as the top screw and both show good streams of pure fuel...no air whatsoever. I've done this a few times just to be sure, and no air, but I can still stall the tractor on incline.
I just realized yesterday that I believe the cause to be inclining the tractor going forward to around 30 degrees incline or more will cause it to stall/die...however, if I go up the same slope going backwards, the tractor does not die...or if I go down any slope going frontwards, the tractor does not die.
One thing I did replace is one of the ferrels (olives) on the fuel line going out of the CAV pump to the front injector because it was leaking there...the old one looked to be harder than brass, but I replaced with brass and this caused the leak to stop...I can't think using brass would cause this problem...in addition this problem existed before and after this fix.
So now I'm thinking it may be the CAV pump being worn...but I thought I would ask since maybe someone has experienced this incline only issue and may recognize the symptom for the problem. Thanks for any advice.
Another idea, just a shot in the dark, is either my valves are off (but I remember adjusting them properly at the start), or my CAV is turned (timed) just a hair off from what it was before the rebuild...even though I was sure to match the timing lines when putting the CAV pump back on.
