used red MN
- Location
- Coon Rapids, MN
What does the YT brain trust suggest as the best way to set a treated 4x4 fence post for a yard privacy fence? I redid my fence about 15 years ago and now two posts have rotted off just above the concrete I poured them in. Searching for info I see it is okay to use concrete if the very bottom of the post is left in contact with soil. Which means you are essentially setting the post in a concrete sleeve. The reason for this is so moisture in the post covered with concrete can migrate down an go into the soil. This is opposed to the method of digging the post hole placing some cement in the hole and then setting the post then adding additional cement to set the post. I have yet to get the old post out to see how it was set but I am pretty sure we put the post in the hole and just poured the cement around it. By the way removing this post in cement is a very labor intensive job for a 60 year old man. I am actually surprised the concrete around the posts breaks up as easily as it does.
