This is my first post, hope everthing works right.
I bought a 1966 Ford 3000 diesel that needed some work, nothing serious yet. I do have the Ford service and operator manual. One of the
issues is I believe it is stuck in either the draft control or position control position. When the lever is fully up it is facing forward
and horizontal. When I push it down the end of the lever only moves about 2-3 inches or about 20-30 degrees. Is this normal or should it
move 90 degrees (as it looks like in the manual). When the lever is up it will lift my 700 pound rotary cutter off the ground but with the
lever down it will only lift it until the top link pulls on the draft control main spring. I figure I'll have to eventually rebuid the
system but I'm hoping lever is part of the problem.
Thanks in advance,
Steve
P.S. I just had spinal surgery so doing anything too strenuous is not going to happen at least for another 10 weeks.
Thanks in advance,
Steve
