1998 Ford 5030 MFWD
Fuel inj. pump: Cav DPS (I believe - no markings found)
I changed the fuel filter and cleaned the water separator.
I thought that I had completely bled the filters, but after starting and pulling the tractor out of it's shed, she stopped running, obviously because of air in lines.
After looking at a few videos and forums on the subject of bleeding the pump, I unscrewed what I thought was the injector pump bleed screw. After a bunch of extra searching, I found that it was actually the Latch Valve that I took out. What an idiot.
So now I know fuel is getting to the inj. pump, but nothing is coming out at the injector lines, even when cracked at the distributor-end of the pump and Throttle fully open. I don't believe this pump has shut-off solenoid.
Did I really screw something up inside the inj. pump?
What can I do?
Thanks!
-Doug
What can I do?
Thanks!
-Doug
