NS-JG-Jubilee
I've spent a bit of time looking around these forums and found the advice here quite helpful, so I'd figured I'd post to see if anyone might have a solution to this issue.
I've got a Ford Jubilee with a no-spark condition.
Several weeks ago, the tractor was idling while we prepared an implement and it suddenly quit. No backfiring or sputtering, it just quit as though the key had been shut off. Typically when this has happened, the tractor was just out of gas and needed to be refilled. Not so this time.
After filling the gas tank, we drained the battery trying to start it. The engine was cranking (I hope I'm using the right term here) but wasn't starting or even trying to.
At this point, I began diagnosing the ignition system. I checked all the spark plug wires for continuity, and they all passed. I also put a circuit tester between the ignition coil and points to check that the points were working, and the light flashed when the engine was cranked, so I ruled that out. I also tested the ignition coil, and it yielded a bright blue spark. I also replaced all four spark plugs. I checked the continuity on the rotor button, which was good. And I checked the continuity on the posts on the distributor cap, which was also good.
Eventually, I determined that the coil was sending a good spark to the distributor cap, but the spark wasn't being distributed to the spark plug wires.
After consulting with a mechanic friend, I also replaced the condenser and points, gapping them as per specification. I also replaced the battery. I set the timing by turning the flywheel to 8°BTDC as per the indexing marks, and then gently turned the loosened distributor while cranking to try and get the engine to catch. I did this because I thought that somehow the rotor may have gotten out of phase with the posts for the spark plug wires. Still no luck. I've also manually checked to see that spark is getting into the distributor cap by grounding the terminal, and I also manually crossed the centre post in the distributor cap to a spark plug wire post to check and see that spark could in fact go to the spark plug wires and it did.
At this point, everything points to either a faulty rotor button (which seems unlikely given that it has continuity and is in good shape), or that the rotor is out of phase with the posts on the distributor cap. I can order a new cap and button, but seeing as neither seems to actually be broken, I'm a bit reluctant to do so. This afternoon, I'm going to try and adjust the timing once more just to make sure I got it right, but I was wondering if any of you might have some other ideas as to something I'm missing?
I'd appreciate any insights.
-JG
-JG
